Tires: 295/65-18 or 305/65-18
SLC
Pulled the trigger on the Ironman Foam Cell Pro Coilovers this morning.
Now sorting out the tires. Want to run something a little meatier than a 285/70-17. Looking like the two options within reason are 295/65-18 Wrangler Druatracs or 305/65-18 BFG KO2s. Highly likely they'll be going on Method Roost wheels 18X9 6X5.5 4.5 backspacing -12 offset.
Any thoughts?
With that lift I had good luck with the 34x10.50R17 KO2s before I went full 35s with a bit more lift (and cutting).
Did you have to cut anything other than plastic to make them fit?
Pulled the trigger on the Method Roost in Bronze, 18x9 w/ -12 offset. Backordered 6 weeks but will likely be going with 295/65-18 Goodyear Duratracs.
