Tire wear issue?
Tulsa OK
I have 5k mile old 33" BFG K02 All terrain tires on my 97 80 series. I have not rotated them yet. I noticed that the back two tires had a lot less tread than the front. Also significantly less tread than the brand new spare. I thought this was odd as they only have 5k miles. Also why just the two back ones? I figured if any it would be the front. Can anyone chime in on this? What's the issue or is this common? I run them at 35 PSI cold and they go to around 42 when hot.
This first pic is the rear and the second pic is the front
Do you accelerate as quickly as you can from stoplights? Did you adjust your braking proportioning valve to increase braking to the rear?
looks like a little feathering there on the backs as well. thats odd its normally the other way round with the fronts wearing funny due to crappy alignment. I would be looking for badly worn track bar or control arm bushes
it definitely doesn't have the rear locker engaged. No light or feel of it. No weired sounds and the car tracks straight. I can't figure it out. Any other ideas?
