The fender to tire gap is just perfect. I thought the 70's would be much bigger.
The 70s only seem big when compared to stock. When I'm over at ACC (Toyota Truck and Land Cruiser shop in Atlanta) my 70s look like I took them off my wife's MDX.
I did...thanks for the pics. How do you like the metal tech sliders, is there enough of a "step" on them? is the step wide enough for day to day use?
You didn't specifically ask for 305/60/18s, but I wanted to offer another data point.
The 305’s are 32.44” tall. While I can tell there was some minor torque loss, it is insignificant and the truck still has plenty of grunt. I’ve towed right over 6000lbs with this setup and standing starts, fwy cruise, and fwy hills climbs are still rather effortless without any added gear hunting at speed. So you should have plenty of power reserved, even at the slightly taller 70s profile you’re considering.
AHC is not really an issue either. A lifted truck still requires that the tire be ‘stuffable’ into the fender under compression. It only changes where the tire sits in the suspension stroke under static load. My 305’s barely rub under full lock, but you wouldn’t have that issue for 275s.
1meancruiser said:Amazing what a difference tires make. The LC on the left looks like a different model with the A/T's.
