Tire Pressures
I can't find a "Goodyear duratrac" tire in size "285/70/18" anywhere. Are you sure you have the complete tire model and size correct?
HTH
It’s the Goodyear Wrangler Duratrac in 275/70/18. Sorry for the wrong size.
I did find an LT275/70R18, is this your tire?
HTH
HTH
That’s the one! Thank you!
Toyota specs the tire Load Limit for the LX570 as 2315 lbs (2105 lbs for LT tires). To meet this Load Limit the RCTIP for these LT275/70R18 tires on an LX570 is 36psi F/R.
Toyota specs the tire Load Limit for the LC200 as 2512 lbs (2286 lbs for LT tires). To meet this Load Limit the RCTIP for these LT275/70R18 tires on an LC200 is 41psi F/R.
Take your pick.
HTH
Take your pick.
HTH
Thank you! Just put those on a temporarily aired to 35 and they feel too soft, will air up to 41. Appreciate what you do :)
@gaijin I just picked up a new to me 2017 LX570 and was hoping for some guidance on proper RCTIP for my new wheel and tire setup:
Nitto Terra Grappler G3
LT285/70R17 C 116/113S
Thanks so much for assistance in advance. Cheers!
Toyota specs the tire Load Limit for the LX570 as 2315 lbs (2105 lbs for LT tires). To meet this Load Limit the RCTIP for these LT285/70R17 tires on an LX570 is 35psi F/R.
Toyota specs the tire Load Limit for the LC200 as 2512 lbs (2286 lbs for LT tires). To meet this Load Limit the RCTIP for these LT285/70R17 tires on an LC200 is 40psi F/R.
Take your pick.
HTH
Take your pick.
HTH
Appreciate the assist!!
What do you recommend for a 2013 LandCruiser with Goodyear Wrangler Adventure w/ Kevlar in LT285/70r18 125/122R Load Range E?
The RCTIP (Recommended Cold* Tire Inflation Pressure) for those LT285/70R18 tires on your 2013 LC200 is 38psi Front/Rear.
*According to Toyota:
Tire Pressure vs. Tire Temperature
Tire temperature is dependent on “cold” tire pressure, driving distance and speed, ambient temperature and road surface temperature. As the temperature of the tire changes, air in the tire expands and contracts, changing the tire’s air pressure. The cold tire pressure for all Toyota models will vary and will need to be adjusted accordingly.
“Cold” tire pressure, as shown on the tire pressure label on our vehicles, is generally considered to be the pressure in a tire that has not been driven in the past 4 hours and has been parked outdoors.
And don't forget to re-initialize your TPMS system.
HTH
