Tire chains and 315s
Vancouver BC
So, how many fellow mudders chain up in the winters on your 315-75-16 tires? I'm running KM/2 with a low lift, OME 850-860 and am worried about clearance.
Tips?
I have ladder style chains that fit, they're not cables but rather twisted link chain. Cable chains from my local parts store were ridiculously expensive, about 2-3x the price of actual chains.
I've run chains on other vehicles and realize they need to be kept tight, etc. will likely zip tie the tag ends and run bungees on the outside, etc.
Going car camping off pavement this weekend at 7000' and I've been told there's already two feet of snow.
I helped a buddy make chains for his 315's out of a set of semi chains. cables work well on road, but real chains dig deeper for off road use. Keep them tight, and keep speed low when the chains are on.
I don't have tires that big yet, but when I do I'll make a set the same way. Just check the chain up areas on mountain passes once in a while. You'll find plenty of broken/forgotten sets.
I haven't bought chains for my 315's ... yet! We do like to play in the snow, a set on all fours makes the 80 amazing for cutting fresh tracks. I'll be buying laclede alpine SS again. http://lacledechain.com/light-truck-and-suvs/alpine-sport-super-sport
FYI - Les Schwab sells these, just rebranded. I had a set on a pair of 32" mtrs on a dodge pickup and thy worked great and lasted a couple of winters, even though I thrashed them really hard.
1997 lx450: 135k miles, unlocked, packasport
:hhmm: Didn't know that. Thanks. I ran a set on all fours with my 33's. Great chain IMO.
Tips?
If you are trying Whipsaw I would be very careful that those chains do not tear up your fenders when compressed there is lots of places on the trail where you will use up all your wheel travel. Make sure you have a contingency plan in case you get stuck (snow shoes, food for a week warm clothing). If you get stuck at Wells and a big dump of snow comes (which are common this time of year) the only way out is uphill both ways. Just make sure someone knows where you are with a schedule so SAR can be called if you get into trouble.
Post picks one way or another. ;)
I have a set of V-bar chains for my 285/75/16 tyres (dont know the size) but I bet they would fit the 315's as mine are quite large.
On my oil field semi we run carbide chains. The cleats on the chain are carbide vs regular steel like on my V-bar chains. As the chains get used they stretch. And they stretch quite a bit. They stretch so much that you have to remove a cross bar or two other wise they are too long to chain up the latches.
Great place to get free chains is on passes that require trucks to chain up. After one storm I saw some guys with a pickup box full of tyre chains. It was mounded up to the height of the cab. Thats a lot of tyre chains.
Only problem with making tyre chains is the tyre chain tool is quite costly. Unless you make a bunch of tyre chains its cheaper to just buy a set or two. I am sure you could use a chisel and a vice but that would be berry time consuming.
Thanks guys I already have a single set, another set is only another $75.
My main concern is fender clearance.
Last year I did this trip on stock height springs and 315s with minor rubbing. It was dry and warm and there was no need for chains.
This year I have the same tires and the small lift. I'm running a bit heavier though, more people and gear and two dogs. Managed to convince my wife that it would be fun. But now the trail report speaks of snow. Climate change ftw.
Pretty sure V-bars would make quick work of my fender flares and other plastic and steel bits near the tires.
Wheelingnoob, I'm going to the Whipsaw. Thanks for the tips.
A large chain tool is under $100. Good for semi chains.
Semi chains are free if you know where to grab em.
A tailored set of snug fitting chains is priceless and doesn't take long to make.
Knowing how to throw iron when it's crappy out takes a little longer to master.
Plenty easy in the shop, not so easy when you're freezing and it's nasty.
I made up a full set of semi chains to fit my 40 on 35's when I lived in Cheyenne. Worked great. Cross bars are huge, so feel like you are driving down the railroad track on the ties when your on hard packed show/ice. They make heavy tension bands for them, and I ran doubles so I could run at speed on the hiways when they were closed. Had to drive to Steamboat a lot of times by bypassing the roadblocks. Blizzards are the best time to ski the chutes at the top of Rabbit Ears Pass! John
I got a set from orielly auto parts that fit my 315's, I feel don't like I have enough clearance in the front so I only bought one set for the rear. I have used them once and they worked great. I have a medium ome lift and a 2 inch body lift.
That's a trip. I'm running just ome, so I wonder if that will be problematic.
All I know is with my wheel offset, lift, tire, and chain combo I felt like I did not have enough clearance in the front. I also have a bumper and winch. With my setup I have a lot more room in the rear fender and had plenty of room.
Are you talking for road driving or off road?
Offroad or on pavement. My experience has been that if the snow is deep enough to need chains in the cruiser with 315's, that even on a paved road the ruts and holes and snow drifts will still have your axle flexing more than normal paved conditions. My cruiser seems to do pretty well in the snow depth up to about 18" - 24".
