Tire carriers
Do the tube style carrier holes match the 75-76 panel tire carrier holes?
Never checked to be 100% but would say no. Toyota changed the tube tire carrier during the 80 model and that changed the hinge location. If they were the same it would be a popular upgrade. Moving the cushion from the back door to the bottom sill was a improvement for rattles and the dent it left in the door.
They are pretty close I put one one a 76. I think all but the lower two holes on the upper mount lined up. I added it about 15 years ago and sold the 40 about 5 years later. I can take some measurements from my 79 if you want.
I think I used one of the bumper holes and drilled one. Had to drill both holes for the catch. I think it took about an hour to add it.
The pad runs horizontal and both holes would be in the sill. Would also be different between 8/76-5/80 and 5/80+ on the upper hinge. 5/80 a extra vertical tube was added.
Bumper meaning the rubber bumper/guide. One of the existing holes on the sill lined up close enough to use and and I drilled a second hole.
I found some pics (from 2001!). So I drilled the carrier top piece to match the tub holes. The bottom lined up. The sill needed 3 holes. One for the bumper piece and two for the catch.
