Tips for getting windshield out?
It may take a little more than that, just have one person push on the inside upper corner and then stick a screwdriver in that corner and start working across the top and down the side. when it starts to bind a little, repeat on the other side and when the top comes free you can just lift it out....what Rhino said is correct, but these things tend to be sticky.
Dan
If you are trying to save the windshield I would stay far away from prying the windshield out with a screwdriver. Cutting the inside rubber will work, but I always worried about slipping and cutting the interior, but in your case I am guessing there is no interior. The other way that is pretty easy is cut straight down on the outside of the rubber. This will release the windshield where you can pull it out without damage, then pull the rest of the rubber out. I have done this many times, I worked for a glass shop for 10 years. Anyway, just thought I would throw that out.
Scott
I have helped remove a window on a non cruiser rig by cutting it out with piano wire. We fead it through at a corner I thing and grabbed it with a visegrip. Then one of us on the outside and one guy inside the rig and we just sawed back and forth and it cut the seal like butter. We probably had like 2 feet of slack that we were moving back and forth.
E
