I'm replacing my knock sensor and wire to mitigate the code 52 stuff. I am just a few weeks out of shoulder surgery and I was wondering if someone would give me a quick run down of the steps to remove the manifold as I am 1.5 handed right now. It seems like I should be OK with my little Makita cordless impact driver but I would not want to be yanking on something that I will later figure out was unnecessary. So far I have:
There are some TORX bolts down near the throttle body. Do those come out as well?
I was kind of hoping to just move the whole assembly together with the TB off to the side a bit and get to it like that. It's a V6 BTW, but if you've read this far you probably figured that out by now.
Anyways, and insight would be appreciated.
- Removed the air intake on the driver's side.
- Removed the four long 12mm bolts down the middle of the valley
- misc shorty 12mm bolts holding the throttle cable, etc.
- EGR valve on the passenger side with four 12mm nuts
