Timing Question?
Vidalia,Ga
When setting the timing on a stock 2F engine, is the timing mark the BB or the line close to the BB?
Its the BB. Its set at 7 degrees BTDC... (I think)
Here is my problem. To install a new gasket on the side cover I removed the dizzy. When I reinstalled it the motor wouldn't crank. It would spin good then it would act as the battery was dead or the starter was dragging. I then pulled it enough to reposition the rotor 180 deg the other way. No help.
I assumed the ignition timing point had been lost so I used a Haynes manual to fix it.
It would then crank and run, but when I switched it off later it was doing the same as before the Haynes fix.
Let me add this is a stock 1977 fj40 with the stock 2F except for a 32/36 DGES Weber carb.
Some more help would be appreciated. Thanks:confused:
So you were you able to get the points adjusted, and the timing mark in the window, and the mark holds steady at 650 RPM? When it was running was it stable? It would rev fine and idle smooth?
So now, if you try to start it, it cranks for a while then starts to drag. How long do you crank it? I swear it sounds more like a battery that needs charging that anything else. Throw a charger on it then try it again...
Thanks for the help. Yes it was running good before I removed the dizzy. Yes it could be the battery as it had been sitting for about 4 weeks. But, I charged the battery overnight and it will crank for a while then start to drag and then start to spin again. I got it to crank but it doesn't want to idle and stay cranked .
I'm going back over the timing process again to be sure all is set right.
I went over the timing process again according to Haynes manual. With the BB on the timing mark and #1 cylinder @ TDC I hooked up a 12 volt bulb between the terminal on the outside of the dizzy. I adjusted the dizzy until the light would come on exactly on the BB. The problem is the rotor is lined up with the #4 terminal I think. It was the one across from #5. I'm not at the truck so I was going from memory.
Can I just move the wires to make it work? I would rather leave them on the right number.
In my "normal" setup - if my timing is too advanced, the starter doesn't want to crank at all (I am assuming this is becuase the firing before TDC is pusing against the starter).
I never had a case where it cranks fine, then doesn't want to crank - I second the battery idea.
RE: Post 7 - You should be able to move the wires, the firing order is always the same. It would be relatively easy to install the dizzy in any orientation (i.e. so that the rotor is pointing at any of the plugs when the engine is at TDC). Did you take into account the dizzy gearing (which will rotate the rotor) on the install?
Good Luck
Rocky
Problem solved!:bounce: When resetting the timing from scratch it is important to use the compression stroke on #1 cylinder.:whoops:
Once done it cranked instantly. Probably was tired of me laying all over the fenders. Coolerman,thanks for the help.:cheers: This website is so full of info I've been able to get by until now.
