Okay, I'm trying to get my new 71 started.
All I would get is a backfire. So I took out the manual and went to set the timing. I got the motor to TDC at the flywheel. The rotor was pointed at the number 6 cylinder. I seen a note not to worry about that, but I noticed the PO (previous owner) had that running to the #1 cylinder and so on.
So I rewired it correctly and now I have a continous firing with no backfire. So I think I got it right. Looks like I need to rebuild the carb.
If this sounds wrong please let me know, I could use the insight thanks.
