The multi-color tags are "pick-tags" and are applied by the depot when the parts are pulled for shipment. The plain white tags are dealer special-order tags, applied by the dealer when the parts are checked in. Those vary by dealer and not all dealers use them. The hand-written number would be written in by the picker at the depot.
In the case of the lower item the picker at the depot pulled one out of a bulk bag and put it in a plain bag, using only the pick-tag to identify it. This is a common practice with small bin items.
The only numbers that are readable in the photo are the pick-tags. The numbers are for the timing cover o-rings. I can't really see the dealer labels very well but it looks like they may have been cross-labeled. IE the dealer label for the 96721-24022 was applied to the bag with the 96761-24042 inside it and vice-versa.
I can tell you with 100% certainty that neither fits into it's intended place on my timing cover, hence the part back in the bag, and different ones on my rig...now leaking.
.DTAYLOR I'm not trying to be a dick but I can't tell if your photo has a photocopy of rulers being used to measure your o-rings....Make sure the copier isn't changing scale....many photocopiers slightly change the scale....just a thought......get that gosh durn leak fixed. you gotta get that thing on (off) the road again!!
The paper ruler came off a printed PDF file. I don't think it's off, but who knows.
I know, it's off!
The reason being is that the image is printed in proper size and then Fused to the paper. The fusing process is done by heating the paper to 190* C. During this process moisture in the paper is forced out and the paper shrinks. It shrinks more across the grain than with the grain. Copy paper is long grain which means the grain travel with the length of the sheet.
Now there is some 12 year old info from a previous vocation I thought that I'd never use again.
I know, it's off!
I knew there was some plausible BS behind my thinking there was long grain shrinkage!rickster....makin' copies.....![]()
