Located RH side a little below valve cover, near alternator. Wondering if this is the dreaded timing cover leak? See photos
It’s fine. Wipe it off. Check again in 5-10K miles.Located RH side a little below valve cover, near alternator. Wondering if this is the dreaded timing cover leak? See photos
Sounds good. Decided to take a closer look on the left side and it's leaking there too. I'll clean her up and see what happens in the next few monthsYes, it looks like it. I would not call it the dreaded. It is a small leak many of us drive for years with.
Just clean and monitor. Unless it gets large not worth bother fixing it.
I'll do the same for the left side, leaking exact same there too.It’s fine. Wipe it off. Check again in 5-10K miles.
This stuff just works.
...at compromising every rubber seal in the engine that is exposed to oil.This stuff just works.
