Timing Chain Adjustment / Replacement
Al Ain, UAE
I'm trying to decide whether I can tackle this myself or take it in to the dealer: constant metal-on-metal dragging sound from front of engine - sounds just like a chain being dragged around the front of the engine.
Looking through the site and my Haynes, it's a pretty engaging job for me: off with A/C compressor, alternator, water pump, oil pan, drain rad fluid and engine oil, etc., but it's manageable. The inside part I might find a bit harder.
My questions are for guys who have done this before:
1. Removal of crankshaft pulley without puller (just using breaker bar) - how hard is it realistically?
2. Installing the oil jet - illustration in Haynes 2B-13, 8.20, looks like a special tool is required, but instructions don't say - how does the oil jet get installed?
Other than these two questions, any advice for me? Anything else I should change/check while I'm there? Just forget it and drive it to the dealer with all the pieces still on is better than towing it in with the parts I took off in a shoebox and a stupid grin on my face??? :grinpimp:
prossett -
Is this a 1FZ-FE motor?
Before you tear into it are you sure that's the problem? I don't mean to second guess you but there have been very few reports of timing chain issues on the 1FZFE. Does it make the sound all the time?
agreed I would remove all the belts and start it up (briefly and on a cold engine, no water pump) before I tore in for a timing chain, could be one of the accessories or pulleys, ditto the FSM
I believe that 94s had the old style slipper that would break so your diagnoses is probable. Technically you need to remove both the head and oil pans to remove the front cover. You might read through this thread as his problem requires the front cover to be removed and options and issues in not removing the head are discussed.
prossett -
Buddy, free license to second-guess me to everyone!!! You could save me a lot of work and $$$, man - go for it.
Yes, it's the 1FZFE motor.
The sound happens all the time, and seems to be constant and unrelated to rpm (as I rev, it doesn't change). It sounds just like a metal chain being dragged around the engine.
I'll try running it without the belts - good suggestion.
The FSMs I've seen in the past were really confusing; I'm more at a Haynes level of expertise :rolleyes: and the thread landtank refered me to shows me how complex it's going to be... CruiserDan took three 9-hr days! Multiply by 7 for me, with my dropping things and having to do everything 2-3 times before I get it right...
Thanks for your input, guys - here's my decision: to the dealer for a diagnostic and a quote!
Well, the plan is to first run it without the belts - that was a great suggestion. There's still hope it could be a bearing...
Then I'll get the dealer to diagnose and quote $$$, and perhaps peak down without the valve cover - thanks for the tip.
Based on that I'll decide the way forwards. I get three weeks off in January, so that would be the time to dig in, if necessary. I've never taken off the timing cover, but it's a question of following the instructions so it's certainly not impossible - my worry is I don't put it all back together properly, so I'll have to label everything. It'll be a PITA, but I'll also be learning.
Thing is, though - if it really is the timing chain all loose, why is the engine running smooth and perfect? I'd have thought it would run like k'rap with the timing all messed up... so I'm hoping for the pulley bearing.
Over here the "mechanics" are totally completely useless and cause more damage than they fix, so it's either done at home or at the dealer.
A mechanic's stethescope would be easier than pulling the belts. Or use Doug's long wooden dowel method.
-B-
Searched and found: "put a big screwdriver or wooden dowel against the engine when it is happening and put your ear against the other end and see if you can isolate the sound." - cool!
Dougie's usual disclaimers are to avoid the moving bits as you are doing this and make sure the life insurance is paid up and the significant other is standing by with a cell phone ready to call 911.
:D
-B-
:D yeah, I had the friggin hood try and decapitate me the other day as I was poking my head in trying to get a fix on the sound - the hood shocks just suddenly gave way and luckily I just caught it Bruce Lee style (fluke) just before it shoved my head into the fan!!! So warning needed - thanks!
hope this helps
Prossett,
I'm waiting to hear how the belts off diagnosis went. Good I hope. Otherwise, welcome to my nightmare....ooooOOOOOHHHEEEAAAAHHHH:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
:D
-B-
Ohh, that is so fricking hilarious!!! I can just see him somehow trying to hold that thar dowel rod up against the timing chain cover and avoiding all the moving parts and pieces at the same time. Thank goodness we've got Douglas, cool person and extraordinary entertainment at the same time!!! All with the utmost respect as always. :cheers: :cheers: :cheers:
I was getting a visual of a hood shoving someone's head down into the fan/pulleys - ouch.
Hey, if the sound does not change with RPM, then you've got a really wierd one. Literally EVERYTHING underhood turns faster with higher RPM. Are you describing a sound that happens when you're rolling, vs sitting with the hood open. Way short on the diagnosis end of things here to even start looking as so far this problem's not even underhood.
DougM
I had a water pump go out on a 60 that didn't sound like it changed with rpms. It was an awful sound ang the pump didn't leak. I figured it out with a stethiscope.
Little update on this: still have not diagnosed the mystery sound, coz the dealer wants $100 for a mechanic to walk 25 steps and lend an ear, but they quoted around $400 to replace the timing chain...??? Does that make sense to you guys? 100 to diagnose the sound, but only 400 to rip out the whole head, oil pans, everything up front, and replace the chain?
I'm still hoping it's the water pump bearing, although it's definitely not a howling sound which is what I once had from a pulley bearing.
For well under a hundred bucks I can buy myself a mechanic's stethoscope, do it myself, save some money and get to use it whenever I want to!
It must be because they keep getting guys like me asking for their mechanics to step outside and spurt out advice for free! :grinpimp:
