New engine overhaul real time help
Texas
Website
www.peopleschoiceins.com
New engine overhaul, partial do over...
Well I thought I was finished with the overhaul, but ....
Upon attempting to start it up for the first time after the overhaul, a large puddle of oil (about 1.5 quarts) spilled out under the front of the engine.
My first thought is that since it is coming out near the front of the engine, there must be a plug, seal, or something leaking.
I remember getting the front main in all the way, but could there be enough slack in the crank to have pushed the front main out (enough to make it leak) when I was joining the engine and transmission? It was a tight fit, and took a couple tries to get it "stabbed".
Your thoughts...
Next issue.
I expected the engine to start right up, and it did not. Maybe the gas got too old sitting there for...8 months?
Thanks
Where, exactly, is the oil comming from?
X2,
There are several places it could leak, and since yours is a brand new rebuild, it should be pretty easy to tell where the leak is coming from
Dan,
Upon a quick look under the front, I see oil dripping from the far USPS stud / nut that holds the lower radiator hose steel pipe. This seems to be the primary location of the leak.
There is also a drop or two of oil on the USDS bottom timing cover plug.
Is it comming out of the slotted hole that the screwdriver blade is sticking into?
I think so. I bet when the block was boiled they knocked the plug out and a new one did not get put back in.
Dan,
IIRC, wasn't this the plug that popped out of your block when it went Exxon Valdez on you? Hopefully that's not the case for DTAYLOR because that is a #2... i.e. BIG JOB.
:beer:
Rookie2
Where do you think the photo came from?
Well, If that plug is gone I don't see a way to diagnose it short of pulling everything back off right down to the timing cover. Besides, I see oil coming out on the USPS. The place your red arrow points out is in the area directly above where the oil appears heaviest.
At the moment, the engine is completely assembled, short of the splash gaurd under the radiator. I would like to be able to diagnose it without just going willy nilly into a near complete tear down. AGAIN
Any suggestions?
That IS on the USPS.
Have somebody crank the engine while you watch this area, where the timing cover and the block meet, just above the A/C compressor. My bet is that oil will come pouring out in between the timing cover and block.
Pull the coil wire so the engine won't try to start.
OK, I'll try that and get right back to you.... If that is the deal, how difficult is it to get to?
It took me 27 hours.
Dan,
What had to come to ge tthe timing cover off? That will likely be different on the 1FZFE, or will it?
That area IS wet with oil, so I suspect you are right on. (I won't be able to check it for sure till my wife gets our son to bed).
I need to check to be sure, but doesn't the head need to come off / loose to get the timing cover off? Or is it just those first two bolts?
The humanity!
This thread has most of the gory details: https://forum.ih8mud.com/showthread.php?t=8239
Basicly the engine needs to be lifted up off of the engine mounts about three inches and the oil pans have to come off. This requires removal of the sway bar as well. The valve cover has to come off and the accessories need to be removed. The head is supposed to come off but I did it without removing the head. That will depend on if you can get the timing cover to break free without tearing the head gasket up. I spent three 9 hour days on the job.
OK, confirmed it. I have a gusher at the USPS timing cover / block seam. Time to dig back in...dammit!
What I need to know is how did this occur?
Was the guy that vatted the block supposed to put a new plug in, or was it the guy who put the first guy's basket job together supposed to?
Wow, I'll have to remember this. f I ever have to dive in to my 80. If this is the issue, it reminds me of the timing chain cover wear that plagues the 22R/22RE 4 cylinder engines. When the plastic timing chain guides break, the timing chain begins slapping against the metal timing cover. It makes a horrible sound, and this usually alerts people to replace the chain. However, the actual cover itself gets overlooked from time to time, and if the chain slaps often enough, it wears a hole right into the water pump passage thereby pumping coolant right into the engine upon startup.
In the first place this plug, like the bushing, is not serviced by Toyota and you, in theory, replace the block.
Either boiling the block knocked the plug out or it was removed prior to boiling the block. IF the plug was still there, but knocked loose, you would not be leaking as rapidly as you are. There is a boss cast in the back side of the timimg cover that will trap the plug if it breaks free and prevent it from comming completely out. Yours aint there.
If guy number one boiled the block and guy number two reassembled it my bet would be it was gone before reassembly. If you did not know it was supposed to be there in the first place you would not know you had a problem until you just found out.
OK, Now you're really freaking me out. If this plug is not serviced, what did you do on yours? Am I just totally screwed here?
