Guys, this is my first Timing Belt Replacement on the 100s (2003, 195K mi, 2UZ-FE). Everything seems pretty straight forward; I'll post up a video of this job soon, but the alignment of the Timing Belt. I bought a Aisin Prepackaged kit for this job that includes the tensioner, idler, water pump and belt. I also replaced the fan support bracket and pulley and put in a new blue Aisin fan clutch.
The problem is every time I lined everything up with the alignment marks on the belt and with the pullies in the TDC positions (or the TB positions) the crank shaft was just not there after two turns. It was always shy of where it should be by about 3/4"-1" as if it needed to turn that much more to get in alignment. I pulled the belt back off, re-compressed my tensioner rod and tried again (twice more)!
Every time the same. So I ended up following the process, but putting the crank off one tooth on the belt further in its clockwise travel (looking at the front of the engine). And it all lines up! What gives?
I've verified that cylinder #1 in in the compression stroke, and the two cams are aligned with the TDC marks when the crank is now at TDC mark. And rotated the engine multiple times to verify that...
Am I missing something else guys? About to fire it up and see...
