Timing Advance Question...altitude adj.
Berthoud Colorado
Website
www.w2m.com
I am here in colorado in the front range litte bit of altitude.
I have done everything to my cruiser I can do myself except adjust the timing......general maint. Im no machanic, but learning, cruiser came from sea level.
Talking to a machanic last night he mentioned it will run much better and faster if you advance the timing a bit and explained how to do it on paper.
Got home late and fired up the cruiser, warmed it up.
loosend the clamp at the base of the dist....started up the cruiser and began turning (advanciing) the dist.......
There is about a 1inch rotation from low idle to advancing and die'ing.....
My question:
If I advance the timing to where my cruiser wants to run like crap and back it off (retard) just untill its running awesome, but slighly high idle...truck runs like a banshee and ripped out of my driveway....OMG what a diff, but..is a bit louder and races at idle more than I like.
Is thee a happy spot where it should be ? without proper tools and messing with the fuel/air mix idle screws ??
And can I mess anything up by not properly setting everything together.?
thx,
R
Old school "pre-timing light" distributor setting technique:
Advance the dist till the idle speed is fastest. Clamp her down and test drive it. If it pings, back off a little. When timing is set so the idle is fastest, and it doesn't ping, readjust idle speed at the carb.
the old 1960's owners manuals say to put it in high gear(4th in your case) at about 20mph and mash down the pedal, you want it to just "ping" a bit in 4th
you really should get a timing light, yeah you can do it by ear but at some point you will mess up the timing and need to get it back to 7deg BTDC.
if you adjust the idle speed then you need to adjust the timeing and if you adjust the timing you need to adjust the idle speed.
on the dizzy counter clockwise is advance
at sea level I am not able to advance my timing from OEM specs
Great......It was pinging on the first test drive...I retarded a bit.
Can't seem to find the fricken idle adjust scre..haynes man...shows a long looking screw that is not on my cruiser ??
on the carb, side facing the firewall, there should be 2 screws, the one closest to the carb body should be idle speed, the other one is the fast idle(for choke) You are talking about the 40 not the 60(with a Holly)?
on fj60 vintage carbs they came from the factory with a plastic cap over the screws, this was because they didn't want you to mess with the carb which effects the emissions.
Razor,
Read up on adjusting your timing and mixture by vacuum.
You won't need a timing light, just a vacuum guage.
You set your timing for max vacuum, back off a little, make sure it doesn't ping. Then go and set your idle speed to ~650. Then set mixture for max vacuum - maybe back off a little as well.
THEN, change your plugs to some freshies. Run around for a few miles and read your plug color...
AND, come to the next RS meeting (tonight) and ask those guys!
HTH
^its on my stocker 77 40....I moved the dist. about a full inch, I had no idea that this would effect the rig this much......
I will attempt to find the idle adj. screw now...
What a diff. this has made to the power....unleash the beast...it is actually a fast truck now.
Razor - your 40 is a '77? Close enough to my '78...
Look here:
for some reason I thougth it was a 79.........so forget what I said about the carb ;) and maybe even the timing,
Look here:
^this is too much for me at the moment.
I will set the timing so, no ping and adjust the idle screw and have my bro do the complete tune....Thanks all, Im in the garage...:-) Awesome.
Won't make it to RS meeting.........had to drive to aspen yesterday...day trip, need to be out of the car today.
500 mile round trip.... :rolleyes: :doh:
thx though.
R.
