- Thread starter
- #21
Any tips on bleeding the brakes? I installed a speed bleeder for my comanche but not sure if this exists for a 2017...
It takes two people. See @LBridges post below for sequence. The person in cabin repetitively pushes the brake pedal until you see air free fluid. Use a clear water bottle to capture the expelled fluid, so you can inspect. Close the line while the pedal is depressed. It’s a very easy process.Any tips on bleeding the brakes? I installed a speed bleeder for my comanche but not sure if this exists for a 2017...
It takes two people. I’d have to look at the pattern, but IIRC it is RR, LR, FR and LR. Open the line, and the person in cabin repetitively pushes the brake pedal until you see air free fluid. Use a clear water bottle to capture the expelled fluid, so you can inspect. Close the line while the pedal is depressed. It’s a very easy process.
There’s also a way to do it via Techstream that makes it a one person job, but I wasn’t savvy enough to make that work.
I replaced my factory disks with factory disks, but I cryo froze them prior to installing.
Please explain how you did this. I wanna see the look on the chem lab folks when I show up with a pair of brake rotors for them to dunk into the tank of liquid nitrogen.
