tilt/telescopic steering column issue
Belgium
Hi,
I replaced both motors on the steering colum. The tilt works, but the telescopic function doesn't work. Disconnected, the motor works, but when connected not. The bearing turns freely but the colum even by hand takes quite a lot of force to pull out or push down. I already put WD40 on the colum telescopic part but still to no avail. So, what's the solution here? Thanks
I believe you can turn this function on/off in techstream. Are you sure it hasn’t been turned off? I’m pretty sure I turned that function off on my truck when I got it a few years ago.
Swap wire housing block, from working to none working. This helps determine, if switch or wiring issue.
