Tight rear diff?
Decatur GA
I jacked up one side of my rear end so I could spin the diff to align my rear DS and noticed it took a good bit to move. What is normal? How freely should it spin?
Driveshafts still in? Still all wheel drive? Both of the front wheels on the ground? Even if transmission was in neutral, you were turning against the viscous coupler In the center diff which ties the front and rear driveline speeds together to an extent.
jack up the other rear tire too and other than brake drag it'll spin very easily.
OK thanks. Yeah. Three wheels on the ground. DS was out at the time.
Side note, I might need a new thread, but in order to drive, I rigged the CDL by putting the truck in low and then pulling the fuse, then high. When I put it all back together, I must have done something wrong. The gearbox does not engage. Not even park and I have the A/T P light on my dash. I found out after fishing the truck out of my neighbors rose bush. One day I will think it was funny, but I am still shaking right now.
ATP light is strictly to warn you that even though the transmission is in park, the truck can still roll because the transfer case is in neutral. So you haven't got it back into High yet, for some reason.
Yeah it was just a stupid mistake. But I did not know about that disengaged ATP light. Learned something at least.
Thanks for your mistake! Now WE all know about it, too!
(At least the light. I knew that you have to make sure it's in Hi and not N before parking.)
Hopefully no damage.
No, no damage. Just had to pick thorny branches out of my bumper.
I actually think its to make sure you dont take the transmission out of park because theres nothing resisting it freewheeling. Putting it back in park will grind the pawl
Just shut off the engine
Engine was off and when the ATP light was on and engine was off, the Park was not engaged. That is what caused it to roll. I had the center diff in N. I should have known better too because, as mentioned above, it ground into Park. Luckily it was a really light grind so I can only hope it did nothing to the gearbox.
This is kind of a corollary to what has all been posted above.
If you have ONE wheel off the ground (or on ice) and do NOT have the center differential LOCKED (as in low-range), the very same thing CAN happen on these trucks. The only thing holding the truck in place is the friction of the tires and the resistance of the viscous coupling. I didn't believe it until I started jacking up one corner of my truck and away down the driveway we started to go........
Because it didn't ever do that on my OLD 4x4's.....
That was my observation on a previous post. I was getting used to all the ways these things could be locked and could only recall having to get out of the truck and lock the front hubs after simply shifting it into 4WD... Oh the days :rolleyes:.
This is why you use wheel chocks and the parking brake
That works too and the light will go off indicating it is fine
I should have been a little more clear, I meant shut off the engine so you don't grind going into park or gear. The detent on my 95 F-350 is weak and sometimes when I try to shift into 4X4 I go past 4H and into neutral with the transfer case, that's when I shut off the engine. I try to never leave an automatic with 4X4 in neutral.
