Tie rods
Pequot Lakes MN
ok I got some new tie rods and I have my linkage taken off my truck... I can not get the old tie rod ends off..... is there some easier way that I am not finding... Please help....
Soak'em with PB Blaster and give it time. OR..You can always stick them in a bucket of used motor oil for a week or so.
Howdy! After soaking them, put them back on the truck loosely, so you can get some leverage. Use a chain wrench or a pipe wrench to turn the rod. I am guessing you have loosened the end clamps or jamb nuts on the end? John
yea they are completly off the truck...... I might have to soak them... but that will take forever if I have to do that on everyone... assuming I can only do one at a time.... :mad:
Lots of liquid wrench, in between the multiple applications, tap the junctions with a hammer to shock it, then big pipe wrench.
even a small torch will help. after you loosen the clamps, heat up the pipe right by the slit that's cut in it. spray with pb and use a big pipe wrench, maybe even with a bar on the end. i've had to do that before. i had one in a vise, with a pipe wrench and a 3' pipe and i was hanging off of it...and i'm not light.
so is it better to put it on the truck first then take this all apart.... I mean how do I hold the other end when I am putting that much pressure to turn the other end...
Kroil and heat to bust the rust bonds. Repeat as necessary.
I've even taken two hammers, and tapped them together over the threaded area to help shock the rust bonds after the Kroil.
With one end on the truck/vice, pipe / large closed end wrench on the other, twist off.
Once off, I load new tre with copper anti seize.
Good luck.
Thanks guys and girls..... I can not work on the truck tonight... but I will start soaking with oil... thanks!!
Remember to use lots of determination and sticktuitiveness....This helps every time.
You will get it done.
Anger helps, gives added strength. Greatest words of advice for Land Cruisers: "If it's stuck, force it. If it breaks, it needed replacing anyways."
:grinpimp:
Brian
got them all changed.... thanks everyone!!!!!!!!!!!
I love it when a plan comes together!
