Tie Rod Replacement Ends
In my opinion the new style zerkless ends from CC aren't a problem , those boots fit extremely tight and should last a long time . Any failures would probably be linked to extra load forces from much larger than stock tires and extreme wheeling . If there are any issues one could easily upgrade to different arms/rods and use the 80 series ends anyway . I've got CC's ends on my own rig and don't have a problem with that at all , they seem well built and install depth/engagement was perfect .
Sarge
This is a perfect example of a great vendor. I sure hope you put them back into your favorites. They are a great bunch of folks!
Sounds like technology has come a long way. I'm used to greasing all the points under my truck. Now I have a fewer to do. But I'll still check the TRE's. Also I've purchased many items from Mike at cruisercorp, no problems , fast service, competitive prices. I'll continue to use them when I'm in need of something for my 40.
Finished installing the TREs from Cruiser corps, only screwed up one thing. One of the tres is about a quarter inch longer, so make sure if you install them you take the time to look at the 3 smaller tie rod ends and make sure the longer one goes on the passenger side through the hole. Would have saved me about an hour. Here is a pic of the one I'm talking about
It really doesn't surprise me, with most new vehicles today they have hardly any grease fittings. Glad to see the technology is making its way to replacement parts.
Good to know! Thanks for updating. JD
Hijack.
I know Kurt sells the 555 brand, I got some for my fj60 a few years ago and they are good quality... What brand does Cruiser Corps sells? I need some tre's for my 40 and was wondering which one's to get? $15 difference.
Thanks,
ML
