Ticking noise
Tempe, Arizona
I've got a ticking noise now. :crybaby:
Symptoms:
Inaudible at idle
Inaudible while revving in neutral
Inaudible while revving in drive and on the brakes to keep the truck from moving
Inaudible when moving and off the gas
Inaudible when moving and on the gas less than ~20%
Loud ticking inside the cabin, varies with engine RPM
Not fast enough to be ujoints, varies with RPM so it's not a birf
Louder and faster with more engine rpm (ie shifting down to 2 at 50)
The truck rolled over 115k last week and I know it has the following things wrong :flipoff2:
Steering box leaks like a sieve.
Leaks oil (oil is full and 3k old - chevron delo 15-40)
Multiple exhaust leaks (this is not one)
Does anyone have any ideas what could fit here? It seems to be coming from the drivers side of the engine. Are we talking injectors?
Check the little vacuum hose on the bottom of the VSV for the EGR valve. Mine had blown the hose off and that was the location and sound of the noise. Symptoms sound almost identical. Easy fix. The word from Cruiser Dan was that the VSV gets plugged up with carbon and the pressure in the hose is enough to blow it off the bottom of the nipple on the VSV. I plugged mine back on three years ago and I'm still good. Sometimes, it might keep blowing and you'd need to clean or replace the VSV as well.
Good luck.
Good luck.
You're my hero. :) Problem solved.
Thats what I love about this site. Thanks for posting your results. Too many times people don't come back and tell us what happened.:beer:
