I was driving my 1967 FJ40 w a 1973 1F and 2 barrel carb and i was accelerating and when i pushed in the clutch, the engine revved to the max and the throttle stayed stuck open. I turned off the key and when i started it back up, same thing, full throttle.
I checked and the barrel that is drivers side and it has has a functioning throttle plate with weight moving as it should. The choke plate on the main barrel on passenger side is working as it should. I could not see a throttle plate in the main barrel (passenger side) but i can see a silver cylinder/rod with two brass spots that looks like it would have a throttle plate on it but no plate visible. I can manipulate it from the outside and it does not seem to stick but not sure. And ideas?
