Throttle body and intake cleaning
Just confirmed, my fuel filter did come with the 4 crush washers, so I only need the two for the fuel rail line.
Nice, must be a new thing? I replaced mine 2 years ago and it came with no crush washers.
If you are pulling lower your also pulling the fuel injectors.
Add to the list o-rings and seats for injectors
Crush gaskets for the fuel line feeding fuel injector rail. Same ones for the fuel filter also.
6 new connector housings for the injectors as they probably break apart when you remove them.
Might as well do the pesky heater hose. And there are a few small coolant hoses going to manifold/ TB.
Once you go in……you go in deep😂
Do you have the part numbers for “6 new connector housings for the injectors”
I ordered mine through wits end, so maybe Joey throws them in.
Man - this all started with a small oil leak on the valve cover and distributor and now it’s gone full tilt. Yes, I keep eyeballing the PHH now that it’s more visible and I’ll finally attack that with parts that I already have that I’ve been avoiding - breeze constant tension with silicone hose.
I did the Absolute Wits End workaround for the PHH - SO MUCH EASIER
