Three link... has anyone ever...
Thank you... Exactly what I pictured and have thought of doing myself. After 10 years I think it's safe to say the bus load of nuns made it home safe and sound.
Haven't counted, not sure every nun made it, some would likely claim more accounting is warranted, you know, just for a piece of mind?
@Tools R Us
That's great. Tried and proven. I knew I'd seen pictures of that somewhere.
Maybe I'll just cut the front bushing off one arm. I am WAY lighter than most all?) 80s on here. Road driving with the "hitchpin" pulled made absolutely no difference in MY vehicle with the way I drive.
Seems a link up top would be more stable/predictable than a one sided radius arm. But then I run into steering issues.
You can weld on the stock arms, so you could grind a significant portion of the arm down, then weld a small piece of plate to the ground section to retain some of the I-beam shape and structural integrity. My buddy did this for months just to see if it would hold up.
Bigger problem; will this alter the vehicles ability to hold Starbucks cups properly?
Not the best pic, sorry for the potato quality.
@Tools R Us
In watching his rig on the trail and others with a similar setup (buddy built a similar arm, another runes the hitch pin), it isn't as unpredictable as you would think.
How the bracket will survive is a function of how youre loading it. if you're pretending youre ultra3 but with the oem bushings then itll fail pretty quick... if you replace with a heim or other joint with less bind then youre theoretically only pushing and pulling on the bracket rather than torsionally trying to separate it from the axle tube.
Anyway its your 80 and if you enjoy the mods and subsequent engineering and trials and successes that come with it all, rock out. This is a friggin hobby so I dont get why people are hating on your desire to experiment.
You called and hung up.
Weak.
Call again and let's discuss. ;)
And I agree with old @nukegoat ...
**** it all and **** with no regrets.
It was a FaceTime butt dial. Would have been expensive. I was in the middle of nowhere at a dairy in southern UT!
I need you to quit dilly-dallying and move out here so I have a crouch to crash on!
I remember talking about this a while back. That's when I pulled the DS front bolt and drove around. It was pleasant.
Despite the name, there are no cup holders any where on this thing other than the two that need to be wrapped around the steering wheel when my control arm brackets snap off like dry pasta.
Okay, so speaking to you about priorities for a moment; this is mud. Get some cup holders. Stat.
Look at pictures of @nukegoat 's rig; cramming water bottles and energy drinks wherever they'll fit. Is that really the life you want to live? :moon:
When you pulled the bolt, did you still have sway bars on?
Thank you for the pics.
Do you run your sway bar on the trail?
And like @richardlillard1 asked @BlueCruiser84 do you pull the pin with or without the swaybar?
I have tryied both left right combination of front bolt pulled with & without swaybar connected & found one has to remove both to have any benefits in articulation, but the feeling of movement is better when a bolt is pulled with or without the swaybar. Meaning it feels better in the kidneys, less jaring, more fluid, but breaking & steering is a little bit sloppy also. Give & take.
One way I have not tried is removing an aft front bolt, I'm wondering if that would increase tie rod binding???
I have narrowed & ground on my arms, but need to remove a little more to stop metal to metal contact between the brackets, arms & tie rod.
I'm also running shocks that are 2" longer than the OME "L"s in front.
Hope this helps.
Have run all configurations, and prefer both sway bars, all of the time.
Nope. Swaybars are long gone... but so is the roof and most glass which makes a big difference. I also have "stiff" (ome) springs for my weight.
