Three JDM HJ61s being parted out
I am looking for a complete matching lock set (doors, rear hatch, glove box, fuel door) plus keys in ecellent shape (the tiny lock doors should be working, no rust, no binding).
ignition lock is not so important, since I don't think it will interchange with a HJ60.
If you have that, how much would you ask for the set?
thank you,
Jan
Guys............ to mention, one truck is gone, second is almost gone and when I get into the third I will post up more parts with pricing.
Three ptos for 800.00 each.
24 volt wiper motors 75.00 each
rear power hatch lock assembly 35.00
Most of the dash switchs were promised to Iron Giant.
Some 24 volt solenoids for 55.00 each.
Eveything sold fast.
Thanks for the PMs
Rob
how about a high roof clip?
Almost but it had some rust along the ridge.
Have the sunroof glass,motor and tracks all pulled together. 175.00.
parts
I am in need of a glow plug relay..also AC compressor .if same as HJ60...
also.....need wiring harness (arm) LT front (firewall forward)......same as HJ60?
Also...also....lower tailgate????
I will try and post up parts, but if you want something in specific please PM me.
Thanks
Rob
Rob,
stick up some contact info...
makes life easier...
Hi, I'm looking for the drivers side window control switch. It is the switch that clips to the backside of the door panel and plugs into the electrical connection. PLEASE, I need it.
Thanks.
I copied this thread and put the duplicate in the "parting out" forum. It is a new section, please check there too for reply's. Cheers.
Sold just about everything for now, one of the parts rigs was taken by my Abel my partner in crime, he is dropping in a 2002 small block, 700R with stage one and maybe a Orion.
Cable lockers and ptos still ready to go.
Rob
How about the bodies? Are any worth saving once parted out? If so I might be interested in just the body...
Copy that.
Not sure how to do that?
Thanks
