- Thread starter
- #21
Sorry you bought a shìt box![]()
It's not a s*** box. But compared to an actual well performing vehicle the driving characteristics of diesel land cruiser are similar to a shopping cart.
You're literally splitting hairs.
If you can feel axial play, it exceeds you 0.13mm (human hair is around 0.12).
My understanding is that Axial play is more likely to allow the impeller to contact the housing. Changes in boost and exhaust gas pressure push the shaft back and forth axially.
If a compressor floats forward and contacts the housing at 100,000 rpm, you're left with shrapnel.
Thrust washers do wear and fail.
Radial play is more forgiving and better taken up with oil film in the journal bearings, so less likely to contact the housing.
Radial play is measured at the shaft centreline. 0.18mm play at the shaft centre line could be a lot more at the impeller due to leverage ratio. Which is why a small amount of radial play can be more easily felt, and slightly less of a concern than axial play.
From the 1HD-T FSM
Welp, I'll stand corrected.
Non-hamfisted peeps can feel when tolerance is over/under a human hair.
Dusten's Landcruiser is not POS even if it doesn't stop and handles like a shopping cart. But it's ok, coz it's not a sports car?
And @KiwiDingo hate for the CT20B has changed to love.
Oh, wait, scratch that last one!![]()
Curious if you can buy something like this?Do you have a shrapnel collection device on the intake?
Yah I think he's implying an intercooler. hahaCurious if you can buy something like this?
Ahh damn now I have to buy an intercooler. I was picturing like a mesh screen in the charge pipe.Yah I think he's implying an intercooler. haha
I could be wrong! I just know ICs are somewhat jokingly referred to as engine savers, shrapnel collectors etc. I wonder if anyone has made something like that.Ahh damn now I have to buy an intercooler. I was picturing like a mesh screen in the charge pipe.
yup, they have, it just happens to cool the intake charge too! 2 birds 1 stoneI could be wrong! I just know ICs are somewhat jokingly referred to as engine savers, shrapnel collectors etc. I wonder if anyone has made something like that.
Maybe I should check mine, it’s running great but one never knows. Can this engine run without the turbo? Just curious. Thank you for posting pictures, did you notice any noises or vibrations that prompted you to check the turbo?
Ok, in case of emergency, limp home. That is if pieces haven’t gone through the engine.Could. Sure. But man would it be slow.
I wasn't checking the turbo. I was cleaning intake tubing and just glanced down.
Ok, good to know. If the turbo suddenly goes bang, what is the first indication other than a loss of power? Lots of smoke? Grinding/pinging noises? I need good vibes, not nightmares.Yes, but if you have a turbo failure, there's a fair bit you'd have to cobble together to remove the damaged turbo, and run without it.
Running with a broken turbo, you risk the engine sucking in oil, and running away using the oil as fuel.
Ok, good to know. If the turbo suddenly goes bang, what is the first indication other than a loss of power? Lots of smoke? Grinding/pinging noises? I need good vibes, not nightmares.![]()
I had engine runaway wen turbo went bangOk, good to know. If the turbo suddenly goes bang, what is the first indication other than a loss of power? Lots of smoke? Grinding/pinging noises? I need good vibes, not nightmares.![]()
You notice things like oil in your charge pipe long before the turbo goes bang.If the turbo disintegrates it's going to be loud
It's also uncommon.
Slow turbo failures are often indicated by excess blue smoke, a lack of boost and a lack of power.
