I'm confused too. 275/70/18 Mine's suppose to be at 33psi. Actual is closer to 40 psi. I haven't even checked , but it says 35-36 cold then heats up to 38 when rolling. Ride is good. Am I to low? Mine was recommended by discount tire.
Me too. E. 80 max. I've been on /off road for 2k miles. No worries as if yet. Who knows??What is the load rating and the Max PSI for your tires? My KO2s are E-Rated with a Max PSI of 80.
I had started out with mine at about 55 front and 65 rear as I was pulling a trailer. This was in part due to BFG telling me to run them like that on my LR4 which was a vehicle in a similar weight class. As you can see from this thread, Gaijin guided me towards 40-41 front/rear based on some documentation he had. They "felt" find at that pressure though my LC loses control on wash boarded roads. I was wondering if I could drop the PSI down even lower for everyday driving so I had sent something to BFG to see what they would say and I got this. The fact that they are so very different is what has me confused.
I like the 40-41 on pavement. Though I do NOT like the way this truck handles on washboarded roads. I don't mean "off roading". Simply dirt roads that are washboarded. Far worse control than I've had on my LR4, an Acura MDX, 2 Lexus RX350s and a 100 series LC. I was hoping that changing tire pressure might help.
There's a lot of confusion suddenly in this thread, but yours is easy to clear up.
I'm assuming your tires are LT-rated tires, not P-rated tires, correct?
When discussing tire pressures, we are ALWAYS talking about COLD tire inflation pressures, NOT the pressure inside the tire when they are warm after having been driven. In this case, "Cold" just means that the tire is at the same temperature as the ambient air - not having set in the sun and not having been driven for at least 4 hours.
The 33psi pressure recommended by Discount Tire is WRONG. They probably recommended that pressure because it is the only pressure listed on the placard on your door jamb. Only problem is, the placard pressure is for P-Rated 285/60-18 tires, not LT-Rated 275/70-18 tires.
Please don't make me go through all the math again, but based on Toyota's recommended pressure for the P285/60-18 tires, and following the charts and recommendation found in the 2014 Yearbook for the Tire and Rim Association, your Cold Tire INflation Pressure should be 41psi Front/Rear. So, yes, you are too low.
HTH
I had a really hard time with the complications behind what Yoda (OK, gaijin...but I hate typing gaijin for some reason)... is saying...and after switching to 40-41...I am totally convinced.
Like Nike and gaijin say... IT, JUST DO...THERE IS NO TRY!![]()
Maybe because you're pronouncing it incorrectly? It's GUY (as in guys and gals) and GIN (as in gin and tonic). In Japanese (where I lived for 15 years) it means, "outsider" or "foreigner."
And thanks for the kind words![]()
-Love your avatar...So can I drop to 38 and 41 when towing? In other words, drop them down as low as possible while still supporting the GVWR of the vehicle?
Tire pressure is dependent on weight of the vehicle. I run mine at 41-45 psi all the way around. I run all 4 tires at the same pressure.
I also run this pressure all the time except when wheeling were I go down to 22 psi
Maybe you said it earlier, but why are you running at 80psi?
I run 40 psi as well and I air down to 18psi for the beach.I'm confused too. 275/70/18 Mine's suppose to be at 33psi. Actual is closer to 40 psi. I haven't even checked , but it says 35-36 cold then heats up to 38 when rolling. Ride is good. Am I to low? Mine was recommended by discount tire.
Mud trumps BFG.
You guys are great. Solid honest help from peoplple who love cruisers.
