This isn't going to work is it??
Cuba, MO
Here is my problem....I am possibly purchasing HalfShaft5's 1962 40 series, thats not the problem....this is the problem
I like the idea of a 4 speed more than a 3 speed. I have a 4 speed tranny with transfer case that i can swap into it.
I hadn't seen any forseeable problems until i remembered that the 62 has a centered differential. Does that makes this swap impossible?
lunyou
No. The transfer case arrangement is the same as later FJ40s and the drive shaft is at an angle. If this bothers you, you can get a later model rear axle, but if it didn't bother Toyota it is probably OK to run it as is.
pin_head......so the driveshaft sets at any angle in the 62 toward the center?
If toyota designed it, it wouldn't bother me to keep the same configuration. I just figured that there was a different transfer set up.
lunyou
inkpot....do you say "it would work better if you dropped in a later model axle" because it would be an easier set up or does it have to do with more stresses due to the angle?
thanks for the help
lunyou
Yes, early FJ40s had the J30 transfer case and came stock with the drive shaft off set to a centered differential until some time in 63 when the rear axle came with a matching offset differential. There is no compound angle at the U joints. The only angle that matters is the one in the plane of the transfer case output shaft and differential pinion.
