We could not figure out a nice way to lay out the IPF fogs on this 80 so we built them into the ARB. The are in back of the bumper just enough to be protected but it does not mess with the beams much as the IPF fogs have way wide beam patterns. Pics of recessed back up light after the roundup.
Great job on the fog lights. I am not sure if I like the placement of the rear light. It looks like you cut through where the four holes are located. If so, it would preclude you from ever using a bolt on pintle hitch as well as an aftermarket bumper being bolted to the crossmember. I very much like the idea though. If it were me, I might have placed it just off center. I kinda like it enough that I might just give this a shot, off center of course.
Nice job just suggestion you should cut the rear bumper and make it like these instead... and attach pintle hook right in the middle but anyway you did great job (thumbs up)
If you look at your second picture you can see that the rear crossmember angles inward on both sides making it almost impossable to french the light in off center. Yes we did make it so that you cant install a Pintle hook but who realy cares because that is what the regular hitch is for.
