think I have a problem
Helena MT
did a compression check today 85 2F 135-145-140-0-140-135
wet and dry still 0 on #4 stuck a small screwdriver in spark plug hole and can feel the piston going up and down.
Look through the sparkplug hole with a light and see if you can see the hole in the piston.
Probably going to have to pull the head anyway. A leakdown test will tell
you whether the oil is going into the crankcase (hole in piston) or leaking
out somewhere else (blown head gasket).
I'll work on it next weekend and see what I come up with. thanks all
Hmmm. That's good thinking. Wonder if you could diagnose this
by just pulling the valve cover. I don't think it could be rings,
because I've never heard of compression going to ZERO with
rings. What would cause a valve to get bent?
cardinal fang said:
Burnt valve will do the same thing, or bent valve stem or pushrod?
Right, rings alone won't let all the pressure off. Neither will a burnt valve even with a nice big pie shaped chunk gone you'd get something.............even 30 psi isn't rare IF the test is done right.
Does this engine huff and chuff out of the oil filler cap while running? ("chuff" is more descriptive of the sound made than "puff").
What would the "chuff" indicate; pressurized gasses getting into the
crank case -- and therefore a hole in the piston? I have a collegue here
who has a borescope. I wonder if you could stick it in the spark plug hole
and take a look see. Kind of high tech for an F engine diagnosis ....
got the valve cover off today. with the engine running there is an audible chuff coming from the drain hole between the #3 and 4 cylender by the pushrods. and can feel preasure escaping.and see a puff of smoke. obviously need to pull the head, but is it head gasket hopefully or hole in the piston. I stuck a wire down thru the sparkplug hole and felt around for a hole with no luck.
Nah, borescopes are old hat in auto mechanics now a days. Plenty of people use them for a variety of look-see diagnosis. It should see a piston holed easily if it's an illuminated model. Pistons can just crack, or they can lose a chunk out of the ring land area, or they can be blown wide open right in the center. Most of the smaller breaks would still pump up maybe 30-60 psi in a compression test but a big center hole will almost always raise no pressure at all for a zero test reading.
3puppies, No use guessing. It's likelythat you'll know soon as the head comes off what was wrong.
Pin_Head said:
It's amazing how well they will run with no valve and a hole in the piston, but they will smoke a whole bunch.
thats what was happening
Pin_Head said:
Or you could have sucked a valve and have both no valve and a hole in the piston.
If you sucked a valve would you know it by what
you see with the valve cover off? Would the
end of the valve still be there?
Usually the head just breaks off leaving the stem. The tip off is that the stem will have no clearance, no matter hw much you trun the adjuster screw.
Back when I was in high school, my buddy's 235 Chevy sucked an exhaust valve while we were cutting school. We drove all the way back to Sacto from SF trailing an enormous smoke screen, but we didn't get stopped. Burned up a quart of oil every 50 miles. He drove like that for another 6 months.
