thermostat won't open
Rio Rancho, NM
Just put in new thermostat and waterpump, tried burping the system won't go down, heaters not getting warm. When I drive it spews out of overflow and when I turn the heater all the way to hot it makes a constant clicking sound behind controls. What's going on? PO didn't have a thermostat in when I opened it up also.
Did you test the t-stat before installing? If it's OEM it should start opening about 188* and fully open about 194*.
Well, I'd start with taking the 3 nuts loose and checking it with a thermometer in a pot of hot water on the stove .
That's easy enough I was just wondering if there was something I missed I guess I will go buy a thermometer
It doesn't open until a small boil, my thermostat isn't reading so I'm guessing it's over 200 degrees, my question is will it engage and open now that the seals been broken or should I take it back.
Take your time burping it, meaning let it cool down and then add Fluid. Once it gets that hot and no heat coming from the heaters , wait and add fluid after it cools down.
It's OEM brand new, ran the truck for half an hour again after testing it with pan of water, it opens perfect at 82C . I think it's working now I took the truck for a little cruise and it puked out of the overflow...what the heck is going on. It won't leak or go down in my driveway and I go for a 5 minute drive and it pours out!
Open the rad cap, with your right hand squeeze the hose from engine to top of rad, you should see coolant via rad cap fitting. If not continue burping the hose and fill as required.
Then start the engine and allow to heat up at idle until t-stat opens, start and stop engine if required to add coolant as required until squeezing hose results in a filled system.
How much coolant did you add? No heat at idle is a sign of low coolant.
Is t-stat in the right way?
If worried drive without the t-stat till you figure this out.
It also helps to park in a steep incline, nose up. Helps burp it.
Possibly a faulty radiator cap.
The cap regulates cooling system pressure and along with the overflow bottle keeps the system full. If the seal is bad or the spring is weak it won't allow the system to reach proper pressure of 13-16 psi. I don't remember exactly what the OEM cap is rated for but it is somewhere in that range.
The cap has to both hold system pressure and allow the excess to bleed off into the overflow bottle. It then has to allow the overflow to be drawn back into the radiator as the system cools and goes negative pressure.
The level in the overflow bottle should always rise and fall with system pressure and with a cold engine should be about 1/3rd full.
Had a similar issue not too long ago. Replaced hoses, checked tstat and it was fine, burped it and re-burped it. Parked on a hill to burp it. Jacked up the front end to burp it. Nothing. As soon as I would drive I would lose coolant. Ordered a new OEM radiator cap from the dealer and put it on. My other cap was only a six years old. It looked good. Seemed to be in good shape. Put the new radiator cap on and solved the problem. Worth the $!3 or whatever it was.
Lots of vehicles do this. If there's not enough hot coolant ON the stat it can't get hot. open a heater hose to bleed some air or shut it off once it's hot and wait a while. It can be fully filled once it's open. Some vehicles have bleeders to let air out.
hmmm...double check the orientation of the overflow cap.....
if it is backwards - instead of creating a system where the rad pulls coolant from the bottle -
it creates pressurized "purging" system - especially if the cap is tight....
and indeed when hot / pressurized - it will spit coolant out of the overflow.
bf
bf
That is something I never thought about. The feed line from the radiator filler neck must feed the long pick up tube that lives in the bottle. You should be able to read the word "COOLANT" when looking at the cap from the front of the vehicle.
Thanks folks, it has been sucking coolant down the overflow when cooled off but somethings weird, I bet it's the radiator cap, all the off and on and tinkering with coolant system may have been the straw that broke it...cheap fix I hope!
Every time I've burped a cooling system I never even had the rad. cap on. Do exactly this:
remove radiator cap & make sure rad. is full
park on a steep incline nose up
turn front & rear heat on high
run until warm & burped
Easy peasy!!!!!
I've had bum oem t-stats. don't rule it out cause its new. Burb with cap off. I also rock my truck by grabbing the bullbar and using my weight to shift it. Sometimes shakes air out.
