Thermostat temp
Fort Worth, TX
i read a 185 thermo will keep the truck cooler than 160 because it holds water in radiator longer.
Counter intuitive, but maybe...
Thoughts?
Problem with 160f is they stay open all the time in hot weather which can leed to heat soak. Modern fi motors run 210f all day long with a 200f thermostat. Old school motors 185-190f worked best, motor ran about 200f. Radiator was always cooler than motor..
ignition timing is real important, have sen several people spend $$ chasing cooling issues that were tuning based...
Im guessing the fan didnt work as planned..
Fan solved 90% of issue.
Surface streets and traffic it never gets over 190 (without AC)
Highway sat most of the time at 195. Inches up to 200-205 after 15-20 miles.
Need to try everything with AC on
Are you running a 160 or 190f thermostat now??
My 91 sbc ran 220 all day long with a 200 thermostat...
I have a 160 thermostat now. Trying to decide if i go back to 180.
You didn’t think 220 for an SBC was too hot?
With efi the ls motors are desigbed to run that hot 210f,
older sbc 180 or 195 works well...
the 91's stock computer curve was leen causing more heat.. it ran best about 190f.
With todays oils 210 ok, you want to get to a point where it runs the same temp all the time, try a 190f thermostat, if it runs the same with the a/c and on the freeway you are good.. it heating up on the freeway is heat soak or something with the motor.. retared timing will cause heat issues, check thst the advance in the distributor is working..
One more thing the biggest problem with a v8 fj40 is getting the air out of the engine compartment. The Taurus fan and large cadillac engine fans work, anything you can do to get air out will help..
