Thermostat stuck open?
Wickenburg, Arizona
Started up Miss Scarlet yesterday and noticed that the temp gauge is just barely moving and stop just about 1/4 off cold. Heat is working. Not overheating and running fine. Thinking the thermostat is stuck open. What say you wise ones?
Have you tried to use an inferred thermometer? You may get a better idea of whats happening once you know the temperature. Mine was not stuck open, but was installed incorrectly(upside down) never got hotter than 125*F. Opened up the housing, installed a new thermostat correctly and the thing sits right around 180*.
I'm sure the wise ones will chime in later. Meanwhile, Check that your coolant is full, so it can reach the temp sender. Ambient temp is still pretty cool, I still have my winter piece of cardboard in front of the radiator...
These engines tend to run cool.
