Thermostat stuck open - advice.
Portland, OR
I replaced the thermostat in my '97 this weekend and as suspected it was stuck open.
When I drained the radiator the coolant looked pretty ick - so I'm going to go back and do a full flush of the system and back flush of the heater cores and switch to Toyota Red. Since I'm draining the system for the flush I'll tackle the PHH at the same time. *shudder*
The truck has done a minimum of 1200 miles with the thermostat stuck open as it was driven up from California to Portland when I bought it.
What else should I be checking on a truck that's been driven with an open thermostat for goodness knows how long and probably not having the engine at proper operating temperature ? (It took over 20 mins of driving to get the temp needle to shift at all)
It appears to be burning a little oil - so I guess a compression test is in order. Should I yank the EFI fuse to prevent fuel injectors dumping fuel into the cylinders when I'm cranking it over - the FSM doens't mention that but it seems like a good idea ?
I'm a zero :banana: wrench - but intend to do me some learning on the cruiser, as if something breaks when I'm out in the boonies I need to be able to fix it - at least enough to limp home :hillbilly:
Good for you to pick up a :wrench: on your own truck. I am not much a :banana: wrench myself. With the helps of the veterans here, I have learned quite a bit. The more you getting know your truck, the more interesting it becomes.
As for the stuck open thermostat, I don't think it had done any damage. You might have notice the truck had very poor gas mileage as it took longer to get to the operating temperature, and probably no heating.
Why not just flush,fill,replace thermo. and see how she drives.I would pull the trans. pan clean filter and flush till clear fluid. @ cents Mike
I replaced the thermostat last weekend and I'll do a full flush & fill this weekend and switch to Toyota red (green in there at the moment).
When doing the compression check should I yank the EFI fuse ?
Thanks for the advice - it helps a lot.
You don't have to. Just make sure the engine is warm, pull the coil wire and run the starter for the least time possible with the throttle wide open.
Open thermostat? We run some of our vehicles without one, however I know this is not advisable specially on newer vehicle. Just put a new one and you should be Ok.:cheers:
