Build The worlds first 2005 UCK41L SUPER HILUX "Saudi. Spec. Region Edition" Options Package
KOITo,s finally in place and 8000k of back of safety
i have installed a 2.5" OLD MAN EMU suspension LIFT kit now
includes a front diff drop kit
rear load sensor valve drop / extension bracket
rear U bolts longer , gold cad plated
new rear EMU shocks
new front pre-assembled coil overs
this is hands down the best ride i have ever experienced firm and responsive
next up larger BFG's A/T 687 raised whites letters OUT
Kustom KOITo LED AUX / DITCH / Back Up Lamps ..
💯 % composite nothing to ever rust ..
8500k cool max jis lumens ..
Yo Matt found the super Hilux build, hows it going? You going to the cove for fall crawl?
Truck sounds good Matt. What exhaust are you running
BORLA .........
all stainless Resonator B pipe back
my current resonator / collector B pipe is at the END of its life cycle :confused:
so ...........
i pipe dreamed up how best to replace it ?
- YES walker and some other GHETTO brands at rock auto , aluminized steal fancy words for junk metal
- after some home work i realized that is the original B pipe on there without question , so ...
- i ordered one up from my Toyota commercial acct. rep and to my surprise it was ONLY like $40 more approx. then the rock auto ones
- the moment i had it in my hands i put my junk-yard magnet on it , and low and behold its stainless , only minimal magnetism !
- so 5 minutes later on was on the shop-hot-line with my boy @cruisermatt , from cruisermatt';s off road in winter park FL , he is the best TIG welder i have ever seen
and i proposed my idea i hatched for more over all horse power : 🤔
- cut away / remove the LAME new oem Toyota B pipe resonator cylinder shape thing , and sleeve in a straight section of stainless steel tubing instead
- this removal of air flow resistance should translate into more Gitte-up and go , combined with the current K-N real mcCoy cold air intake , AIRAIDE throttle body spacer
and the Borla dual tail pipes current stainless steel system ,
not to mention it will be a whole hell of alot louder i am assuming , more JDM rumble off the green light
see parts diagram below : call out # 17420 will be a all straight pipes section now and all stainless steel too ..........
We jigged up a new OEM B-pipe and deleted the resonator.
Replaced the Toyota part # sticker at Matt’s request of course.
Unfortunately the Toyota 409 material doesn’t lend to TIG very well. For anyone wanting to do this I would recommend getting matching 409 material and appropriate MIG wire that the alloy is designed for
Boxed up and ready to head to Annapolis. :cool:
