The saga continues
SmokingRocks
hopelessly addicted to Cruisers
Colorado
Most of you know I have replaced / baselined everything on the fuel side and almost everything on the ignition side. This was done partly to get the rig running better but also get rid of some studderting and bad engine behavior. While almost all of this has cleared up I still am getting a stumbling idle occasionally and lack of power.. also occasionally.
I notice that when its running strong I receive clear and crisp transmission through my HAM radio. However when its not running at 100% I notice there is a lot of crackles and pops in my reception. Since my antennas utilize the trucks sheet metal as a ground plane it makes me think something is grounding out. And it is slightly RPM dependent.
Anyway digging through the FSM I came across this on the one line diagram.
I notice that the "ignition" also provides the tach signal which then goes to a"noise filter" and ground. Interestingly my Tach died about 6 months ago, I read up here and figured it was normal. I replaced the cluster right before CM16 with one that "had a working tach" yet still have no tach.
So first of all I need to locate the ignigtor (I'm assuming this is the same as the Ignition control module?) and test the wire to the tach to verify continuity. If that comes back OK then test the ignigtor?
This is frustrating because it is intermittent.
The harness highlighted in Orange is suspect as well. Previously I noticed that the wires feeding the Ignition Coil (I3) had broken insulation and lots of sections which were bare. I highlighted the area that I replaced in blue pen. From what I could see that's about where the insualtion issue ended, it was also going to me a lot more difficult to dig any deeper at that time which probably kept me from cutting into it further.
Switching the supply to I3 did great things for the rig. However IF ANYONE HAS A GOOD CONDITION HARNESS THAT'S HIGHLIGHTED IN ORANGE laying around in their parts pile I would gladly shell out some money for it. I was hoping that the ignigtor went through that harness to get to the tach but that does not appear to be the case. Which makes me wonder if the harness between I2 and the tach is also jankified. I'm willing to bet much of this is due to the PO using higher amp rated fuses for certain things.
I have similar challenges.
However I have an seperate ECU controlling the ignition etc with seperate wiring. All due to me turbocharging mine.
My issues started before the turbo build.
Have you cleaned the valve body?
Have you replaced all the vacuum lines.
I am suspecting a TPS failure. When I adjust the TPS angle I find that my idling would get stuck on high RPMS then normal and then stall again especially when on downhill slopes when auto box breaking is involved.
The upper intake manifold was off, cleaned and new vac lines installed not long ago when I did the fuel injector service, fuel pressure regulator replacement, injector harness replacement, cap / rotor / wire / plug replacement ect ect ect.
I'm going to get my multi meter out and start testing continuity. Like I said the previous owner just stuck higher amp rated fuses in instead of searching for the real problems which probably resulted in melted wires.
I think I am going to start trying to source replacement harnesses to swap the highlighted ones below. I heard through the grape vine that the previous owner melted the interior fuse block out and had it replaced. So I think the best plan of action would be to completely remove all of the questionable wiring.
SNIP
That would account for the stuff around the ignitor loom being melted. Have you been through it in enough detail to know if there's any possibility any of the wires around there have been contacting each other or grounding to the body? I saw the hack you extracted, but maybe not the only problem there. It sounds intermittent, but they can't be too far away from that even if not a problem right now.
I think you're onto something with the tach observation, If the signal gets astray due to meltdown, it could cause problems with the radio, truck or both. Been awhile since I looked at my EWD, so can't recall if the tach sensor stands alone or not. If it can be disconnected and leave the truck drivable, might be worth disabling it to see if any improvement.
