- Thread starter
- #21
The Belton is a nice lift. You will have to replace the brake lines with longer ones if you plan to use it. (max flex) I am aslo removing the front sway bar today, so I will let you know if that helps with the flex. (I know it will) I am also extending the rear sway bar by 3" to make up for the lift.
All of this is moot because I am going SOA in the spring (that's June around here) I am not happy with how tall the truck is. With the lift, you get to where the truck "should" be from the factory......but it is not at wheeling hieght.
here is the truck with the belton on 31s
http://www3.sk.sympatico.ca/ppg001/images/DSC03761.JPG
and here it is on 255/85R16 with split rims (sorry I don't have a better pic)
http://www3.sk.sympatico.ca/ppg001/images/117111369waHxul_ph.jpg
:whoops:
