The "power" light turned off
Hollister, CA
Website
www.bww.com
I'm referring to the light that comes on in the dash panel when the button above "2nd start" is pressed. The "2nd start" still comes on when activated, but the "power" doesn't light up anymore. So now I don't feel that extra oomph when I accelarate.
So with "power" indicator light off and the button pressed down, is it still activated? If its not, how do I fix it? Anyone else have this problem?
do you drive around with the PWR depressed all the time? then likely the bulb is burnt out,
you have to remove the cluster to replace the bulb, they are a Toyota specific bulb.
It is a common bulb to burn out, it is probably still working.
Maybe while I'm at it I'll take care of the "D" light too.
With the "power" light not working it seems a little less powerful, but that' probably all in my head.
I'm not sure I do, but I'd like to know. My bulb also does not light up, but with the button depressed the tranny shifts up at a higher rpm than when the button is not depressed. So basically it holds the gear longer.
Is that all the power button does? BTW, it's marked ECT on my dash.
Prossett,That's all it does.So, Silicon 70,You should easily be able to determine whether it's functioning regardless of whether the light's working: Take a few runs from a stop with it depressed, and a few identical runs without it depressed. There should be a noticeable difference in the shift points.Curtis
both power & 2nd button indicator light are not working. I tried replacing them today & found out that the "PWR" indicator light is burnt out but not the 2nd button. I've replaced both of them but still indicator no lights comes out after depressing the buttons. I did try to drive it though today with the PWR button depressed & noticed the difference in shift points. I still want fix those indicator lights any other ideas now that I've changed the bulbs?
