Factory lockers front and rear.
I got the gears from Ring and pinion biz in the vendor section. They are Precision brand with the master intall kits. It was $ 845 to my door. They also have everything to rebuild the front and rear axles. I bought all of the seals from CDan, but I bought their wheel bearings(Chinese)
I seriously thought about doing the gears, I work with a guy that has done a few (9") and we talked about it, the big problem is getting a set of "dummy" bearings. I talked to the gear guys and they said not to worry about getting the carrier bearings, the pinion bearings yes, but the carrier bearings rarely wear out, so save your money there. Well those are the "dummy" ones you need.
So I will just tear everything down and haul the thirds to the driveline shop in Carson. He quoted me $ 250 per third. His shop is less than 10min from my office, so that will make it easier.
I am collecting parts right now, I have too much going on right now to tear into it. So it will be a few months. Most likely November before I get into the hard parts. I am getting ready to get some serious work done on my garage. I have two single car openings. Well the guy that built the house, was a brick mason and built the house out of brick. The problem is that he arched the door openings andl I can barely get the 80 in my garage. So I am getting the brick cut away and one single 20' wide x 8' tall garage door installed.
They have to frame everything out to support the roof of the garage, then cut the brick, then the real frame, then the door install. Getting all of the permits and engineering done now, hoping they can get started soon.
Jack
