The Numbers are worn off!!
Any one know how to Identify a 2F motor when the block # is worn of on the passenger side? all I can make out is 2F. I need to replace the oil pan gasket and i'm not sure if their is any difference in the block over the years of the 2F. Plus it would be nice to know the exact year. Next question, should I use a Toyota gasket or is there another one that you all recommend?
I'm pretty sure the pans and gaskets are all the same. CCOT lists them that way at least. if not 2f's went from 75 to 87. I've got a napa gasket on mine, hasn't leaked (at least not from the pan gasket) for 3 years.
Did you clean it with some steel wool and lacquer thinner? It doesn't take much paint or grease to make it really hard to read. On mine the actual # is stamped much lighter than the "2F" part of the serial #. As to pan gasket, just make sure you use a one-piece gasket, IIRC ther are some four-piece ones that you will never get to seal.
GL
Ed
I would recommend always using an OEM gaskets. I have known people who haven't and had to redo things. Cruiser Dan can get you one at the best price if you can wait a couple of days. He can get you the right spark plugs and lots of other stuff you should have on hand for your 40. He is the Parts Manager at a Toyota Dealer
