Ok, I have the Aqualu tub on my Land Cruiser, so I'll clear up some issues.
The aluminum tub is wonderful in that it will never rust. The metallic properties of aluminum are such that if it contacts any metal but stainless steel the aluminum will corrode. Also, if you have an iron bar and an aluminum bar, both rated to hold 10,000 lbs, and you hang a 2,000 lb weight on each one, the iron one will hold indefinitely, whereas the aluminum one will eventually snap from strain. KEY EMPHASIS ON STAINLESS STEEL HARDWARE!!!! Use a rubber inner tube and cut out templates to insulate any metal other than stainless or aluminum.
To combat this the manufacturers of the tub included Sikaflex, which is like a silicone sealant, and is black and is the nastiest $#!+ that I've worked with - don't get it anywhere you don't want it, it's a mess to clean off if it does come off...
Mating the tub to the body is interesting in that you have to line up the tub with the cowling/firewall, and then drop in and loosely tighten the bolts holding the tub to the frame. A couple bolts hold the tub to the firewall/cowling, which is insulated with Sikaflex. The aluminum running boards included look nice if kept polished aluminum, and Sikaflex is used to insulate between the fender/cowling region and the aluminum. Floor mats are a must when the finishing touches are made... You might have to fiddle with the gas pedal in order to get it to completely go to the floor without sticking (bad problem if uncorrected!!)
I would still put undercoating like Rhino Liner on the underside to prevent rock dings and such, but it is up to you. A good friend of mine whose frame and tub were like swiss cheese is putting an Aqualu tub on his new frame from Hadley Industries on his to restore it. I highly recommend both the tub and Hadley. I am completely satisfied with the tub, and if you would like to view pics of it installed, go to
http://www.cardomain.com/memberpage/464154 and have a look.
*On an interesting note, the stock Land Cruiser FJ40 body tub weighs 650 lbs... the Aqualu weighs 350. When dad and I pulled off my tub, it weighed LESS than the aluminum we put on!! Kinda makes you wonder...
