i have a 84 that also stumbles. I am running on a weber 38dges carb. I plan on replacing the small filter with a 10" hopefully today. I think my 60 is starving for air. My truck is also desmogged.
Just picked up my 85 from a great mechanic. My exhaust manifold gasket was blown creating a leak which is what was causing my classic stumble. He also rerouted all the vacuum lines. Problem is gone. My idle is super high, at 1400 so I'm going to work on bringing that down. It wa high to help compenate for the xhaust leak. I hope this is my cure.OK, I'm on the road for work, reading this thread about the frustrating (for me and my mechanic) stutter/miss/stumble.
Going to try the tach disconnect Friday on my 85 FJ60.....will
report....Buzz
Gimpey I know I'm a bit late on responding to this, but the air cleaner won't help you with this. Its a minor performance tweak,nothing that would cause a stumble. First check your jets and make sure they're in the right range. Then unscrew your idle jets and idle mixture screws completely, clean them real good (wire for the jets) and blast that passage in both directions with carb cleaner. Also make sure your simple tuneup stuff is all sorted (Timing/plugs/wires/ no vac leaks/etc)
so i had a buddy of mine come over one day and we did alot of stuff to my rig. We adjusted the carb a bit and it seems to run amazingly well now. U were right about the air cleaner but i still think i am better off with it. Until the motor is nice and toasty it stalls sometimes but within minutes that is gone as well.
I am reposting a question from the old Sor.archive in the hopes that there is some new insights out there. I have the same problem and am stumped beyond the simple fixes. I hope the experts can help:
From DogBoy #1007:
Sorry for the long topic title but it seems that there is a very common problem with a great deal of FJ60's out there, (mine included) and after reading this forum for several months now, I have yet to find a definitive answer to our (all the 60's owners) dilema.
Here's the problem using descriptors from several earlier posts:
•engine "stumbles/hesitates/sputters/stutters/runs rough/chokes out/feels fuel starved/or almost dies" under acceleration, especially in the lower RPM range of the power band.
•in several cases, the engine will idle normally without problem until a load is put on the motor (starting off in 1rst and then into 2nd gear, pulling a load, or climbing a hill...).
• also, many of the posts describe this as being a consistantly intermitant problem...
• sometimes it runs great for a few minutes (10-20) and then starts acting up
• and sometimes it will start/run/drive normally for several miles during a trip and then inexplicably run rough, and then just as mysteriously clear up for the duration of the trip.
Many probable causes have been suggested in reply: • faulty carburation
• poor fuel delivery system
• leaky or plugged fuel filler and fuel breather tubes
• clogged fuel filters
• blocked air filter/air intake
• faulty ignition coil/limited spark
• vacume lines leaks
• faulty EGR valve or other emission equipment failure
• and/or potential exhaust system issue (bad cat converter, O2 sensor, exhaust manifold leak).
Most of the solutions focus on a faulty EGR, with fixes including bypassing the EGR.
What are your ideas? Thanks.
