Okay, so I am in exactly the same position as "livrlarg", I too have a 1991 FJ80 with a 3FE. Mine has 285k miles on it and I am trying to figure out what to do when it finally gives up.
All the good things said about the 3FE are true; very reliable, starts right up, runs forever.
The bad is that it has no high speed torque, and I am lucky to get 11MPG. I could settle for either one of those, but not both. Give me some passing power and highway hill climbing power, or give me more gas mileage.
I had thought that maybe a diesel conversion would be great, but it does sound pretty expensive.
So if I just had the 3FE rebuilt, is there anything that can be done to kick this thing up a bit? I haven't wanted to drive this tired old one a lot harder for fear it would just break. But with a new rebuild, maybe a turbo or something would make sense?
Any thoughts?
This is not a case of wanting to swap just for the heck of it, this engine is going to eventually wear out and I will need to replace it with something. Either the same engine rebuilt, a V8 gas, a diesel, or something?
Ideally:
1) Low cost replacement
2) Much more passing and highway climbing power
3) better gas mileage (18mpg?)
4) Similar reliability
A diesel would be very attractive in every respect but #1. The only way it probably makes sense is if I got a wicked deal on a used one in good shape, like from a wreck salvage or something. Pig in a poke that, hard to know what kind of shape it would be in. How hard would it be to do a diesel engine rebuild at home?
A V8 gas would be a pretty good option. Might even end up giving better gas mileage if it didn't have to downshift two gears every time it climbs a mole hill.
Rebuilding the existing engine might give me a gain in #2 and #3 if this one is not performing up to its potential due to age, but I've read the 1991 reviews of th is vehicle reporting how gutless it was (is). With a turbo, or some sort of boost to the EFI?
Hummmmmmmmmmm??????????
Going to have to do something. Tired of having 1200cc VWs pass me.
Cheers!
