Wow yours was well machined if it doesn't have any material removed for balancing! The joys of cnc milling! Yes you will still need the whole assembly dynamically balanced, at least to check that it's all in spec. One day I'll install mine.
I already did (as mentioned above) and they said it was balanced...The wheels I had done by Sumalaya had a very visible balance mark. I would ask the shop for curiosity sake if it was balanced before hand. I would bet you it isn't.
The bouncing needle sounds like compressor surge. Does it go away at higher rpm? How big is the compressor wheel inducer?
Next step for you guys is finding a better turbine wheel with aerodynamic blades. That one is a paddle wheel!
This feels like a different motor, the usable power band is significantly larger, turbo spools earlier, less downshifting and it is much more enjoyable to drive. I am sure the intercooler is significant in this change too.
After installing the same intercooler with a stock turbo, the motor feels roughly the same, minus a few egts. It changes the way I drive for sure, but I'll bet most of the benefits you see are from that turbo. (May be wishful thinking as I'm after the same setup.)
Was wondering the same as Dougal, thinking extra boost may have freed up the spring or pin? but I think Serenity has 1HZ, so may not have AFC?
Edited
