In keeping with my yearly holiday season giveaways, I've decided to do two this year: one for Thanksgiving and one for Xmas time.
This year's Turkey Day giveaway will be a full rear axle rebuild kit of course using the finest OEM Toyota parts I can find...
This kit will include the following:
-- 2x 90311-62002 (Rear hub oil seal)
-- 2x 90310-35001 (Rear axle shaft oil seal)
-- 2x 43422-60040 (Rear axle shaft flange gasket)
-- 2x 42419-60011 (Rear axle lock nut set screw)
I am not including the bearings because most of the rear full floater axles that I have dug into have shown relatively little to no wear on the bearings. My rear axle at 125K were the original bearings and probably the same grease. When I dug in after my roll over in 2007, the bearings were immaculate and the Mobil 1 I had thrown in was virtually the same consistency from when I had rebuilt it two years earlier.
My apologies in advance to the semi floater 1991-1992 guys--I am pulling parts from my own stash for this giveaway and I obviously do not have parts for the semi-floater. As such, I have decided that I will do two drawings:
One drawing will be from the bucket of folks with full floaters (usually 1993-1997, though there are some exceptions as Dan and I have talked about in the past). The person that wins this drawing will get the rear axle rebuild set.
The second drawing will be from the 1991-1992 trucks--and those 1993 oddballs with semi floaters--
--. You guys will get another prize to include a Firestick CD antenna, OEM Toyota 12V sockets, and some other goodies that will hopefully be just as good as the rear axle rebuild kit.
You can only enter once by posting here. Posting will cease at 12noon on Turkey Day, Thursday November 27th.
CDan will pick the two lucky winners that day when I stop by to steal some grub from his table!
;p
Good luck all.
Best regards.
-onur
;pGood luck all.
Best regards.
-onur
