I finally had som
e time today to get my sPod installed. For those of you who aren't familiar with the sPod, it's basically a fuse/power distribution/switch system. It consists of the "source" which hooks up to your battery and has 6 40-amp bosch-style relays along with fuses (3 15-amp and 3 30-amp but you can swap these out to whatever you want). It also has an inline 50-amp circuit breaker and a low-voltage cut-off.
All of this is connected to a 6-switch panel via a single cable. The idea is that you run the cable for the switch panel once and then in the future you only have to run wiring to the sPod source system. It's not cheap, but from what I can tell it's about $100 or so more than buying similar components yourself, and it has the low-voltage cut-off which isn't something a "home brew" system is going to have.
As far as I know, I'm the first install in a 100-series. I used the Tacoma kit and had to tweak the mounting bracket a bit to make it fit.
Toyota Tacoma sPOD Kit
I mounted the switch panel in my sunglasses holder. Sorry I forgot to take pics while I was doing this but basically I yanked it out of the car and used a dremel to cut a hole in the front for the switch panel (using the provided template from sPod) and then cut another hole in the back for the cabling. It just barely fits in there.
I ran the cable through the firewall from inside the cabin into the engine bay. I then ran the cabling up the A-pillar and across the top of the windshield, connecting to the switch panel. I removed the sun visor as well to make it a bit easier to tuck the cable up out of the way.
All back together:
I then mounted the source system in the engine bay up next to the break fluid reservoir. As you can see, I had to tweak the rear mounting bracket a bit so it would sit flush and clear the hood strut.
With the cover on:
It works!
All-in-all, this is a pretty slick system. Right now I only have my ARB twin compressor hooked into the sPod. I don't have lockers, but if you do, sPod has a super easy wiring kit for ARB compressors with front and rear lockers (using the first 3 switches of the panel).
If I have some time this week, I'm going to run the power for my fridge into it so that I can switch it on and off from up front. I'm also planning on adding some aux lighting so that will get wired in as well.
