Tested My E-Lockers This Morining, Help!
Pryor, Ok.
After reading a post this morning I went out and tested my e-lockers on our gravel drive at work. They work they locked in could tell the way the wheels draged. Now the problem is the rear is not unlocking. The light is staying on even when the switch is truned to the unlock position, can still here the rear wheel drag. I'm new to all of this and I need help.
Mine do that too. Put it in reverse, and turn the steering wheel, while you back-up. Make sure you have the elocker switch in the off position. This method works for the front elocker also. Sometimes you have to go back and forth a couple times.
Thanks Guy's This worked
You need to exercise them more.
x2. Just like muscles, lockers atrophy when not used regularly. Ok, well not exactly like muscles...
:steer:
