test drive... bad newsss... (help!)
Sunny South
well, i did a tune up on my 71...new plugs,filters, all fluids, and all the other little stuff. I was on my way from my house to go to my bud's to weld up new shock mounts so i could get it inspected this week.... i haven't driven this thing more then a couple miles since i purchased it a month ago because its not inspected...
btw - i have a weber :frown: and an electric dist.
anyway, about 2 blocks from my house it started to bog down and die, i'm pretty sure its a carb. problem because when i applied gas it just died again. the one barrel looks a little flooded... but the linkage on the weber seemed like it ran on one barrel then when it was floored the other one opened up??? but the one thats constantly running is alittle blackened and so is the bottom of the air cleaner lid....so is it running rich? but why would it bog down like that all the sudden? i can already see asking this question would entitle a million variables the could be happening....and when i got it back here finally with some effort and tried to shut it off it kept deiseling...first time this has ever happened to it...possibly a stuck needle or something??
.but any info would help....i mean i had the top part of the weber off and everything seemed to be functioning properly and was extremely clean...
:frown:
"Bogging down" isn't much to go on.
Could be fuel starvation. If so, the carb bowl would be low or empty when it occurs or a fuel delivery problem so no fuel is getting to the carb. How much fuel does the pump deliver in 15 seconds of cranking?
Could be flooding. Maybe the needle valve is stuck open and fuel is pouring out of the vent tubes. Do you see a puddle of gas at the bottom of hte intake manifold?
You are going to have to dig a little deeper and provide a better description of the problem if you want better guesses.
i took off the carb and there is a pool of gas on the bottom of the manifold, i think its a problem with the adapter plate. the first plate screws in fine, then the second plate that screws onto that never fits right, i had to get longer bolts and i thought it would work but the one screw feels like it isn't grabbing any threads, i'm gonna go get longer ones and try and solve that problem.....
i checked the needle valve and it seems like its seated properly but i'm not to carb-friendly
in the long run i just want to sell the weber and get a freshly rebuilt stock carb...
but i still have no clue whats wrong?
when i meaned it bogged down, well i was driving then lost power, no matter how high i revved it and then it would shut off...when i tried to start it, it would start up then i try to give it gas and it would automatically die again....
do you have a new fuel filter on it? have you tried running a line from a fresh can of gas?
does your weber have one small and one large barrel? the 38s are mechanical advance, the 32/36 run as you indicated, the one opens up as needed.
check the plate as you suggested, make sure the top bolts don't bottom out before tightening down the plate
bk
Long ago, I had some bogging with my weber and it ended up being caused by a warped plate. It was sucking air below the carb and starving for fuel under high vacuum, and would run fine at low vacuum. Got it machined flat, sealed it and the prob went away.
Try the old aerosol around the carb/plate while it's running trick and see if there is a significant vacuum leak.
By what you said about the plates it's just one guess out of a many possibilities.
if there was a significant amount of fuel in the bottom of the intake, i would say it is flooding pretty badly. i would tear apart the carb and rebuild it or if you have access to another carb, throw it on and see if it runs better. my bet is that it is a weber problem.
I just went thru 3 days of work on my weber 38 only to find a non-carb related cause - so don't be so sure its the carb. Many of my symptoms were similar to yours. Do you have good vacuum and is it a steady reading? Have you checked that the emissions stuff that is on is functioning properly?
But since you mentioned the carb - do you have a manual choke or e-choke? And have you checked if its working correctly? The choke plates can also get stuck closed so make sure they move freely.
From what I learned, all webers run on 4 circuits - Idle, Progression, Main, and Accelerator pump. Most also have additional circuits for starting (choke) and power. If you are sure its flooding (and not fuel starved), you can start narrowing down the list of potential culprits. Immediately, I would say Idle and Progression and Accelerator pump are not causing flooding. That leaves main and Power. Main jets are in the float bowl and that gets fed via the needle valve (fuel inlet valve). If you are sure this is good (valve opens and closes as float level varies) then also make sure the float level is set correctly to properly turn the needle valve on and off.
If you do all that and still have issues than it may be your power valve if you have one. Note that the power valve is designed to support sustained, high load/rev operations so normally wouldn't be activated unless you are running at higher speeds/RPMs. Its vacuum activated with a spring loaded diaphragm that opens when there is low vacuum (high pressure) in the intake manifold. You should check that this is not stuck open which would basically pour more fuel directly into the main circuit and cause flooding.
GL,
AndrewT
