Yes, 2005 LX470. US specs.Yessss! Yours is a 2005 right?
Well, it didnot fire up from the first go...Very excited to see this thing fired up!
@CBeckFJ - It does not. I did however find a wireless CarPlay adapter on Amazon that I'll be trying out when it arrives.
Checking back in here with an update:
- Never got the factory AMP working. It's pretty clear the 'Amp On' wire is not lighting up the Amplifier. No help from seller. Reached out to Navihua as well, and they didn't have anything to offer.
- Moving forward with 5 channel amp install for my system. Will use head unit AUX out connections > AMP > New speaker wiring. Most cost effective upgrade I found after reviewing a bunch [amp bypass, etc, etc etc.]
- CarPlay - as mentioned, found a brand new wireless[!] dongle on Amazon and will be wiring that up to see if it gives me another added level of awesomeness.
.. as mentioned this does take a minute to boot up. Most Android systems do.
Installed into a 2003 LX. OE NAV plugs are different in 03 than 04+ And included harness didn’t work. With the 03 and 04 wiring diagrams I was able to hardwire it.
I have gone back and forth with the supplier of the unit I purchased on the included wiring harness for the 2003 model. I recently received a replacement that is a correct plug-in-play for the 2003. They referred to is as a "top model" application. Good news is it exists and works
I also purchased and installed their recommended back up camera at the same time.
So is there a consensus on if this is worth it or not? I'm planning QOL upgrades and am trying to decide on going this route or the full HVAC-double DIN swap in my 04.
Are there instructions on how to mount the camera? Where does it go? . So, the new harness did not come with the unit?I have gone back and forth with the supplier of the unit I purchased on the included wiring harness for the 2003 model. I recently received a replacement that is a correct plug-in-play for the 2003. They referred to is as a "top model" application. Good news is it exists and works
So far, I would recommend it. However, I don't have the correct harness yet, so my climate control is not working
